Hood question
This is probably a dumb question, but is there any way to put a NNBS GMC HD hood on my NNBS SIlverado? (reason i ask is because i found a good deal on one locally)
Thanks guys
What year are you talking about? I know on an 11 you can put a 2500 hood on an 1500 but not a 1500 on a 2500. I wanted a 1500 hood for my hd but it would not fit. :jester:
The leading edges of the hoods are different . My GMC has a chrome trim piece attached that forms the top section of the grille surround when hood is closed.
If go for the bumper too. That 1 piece looks good
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I thought I read here that you would need to replace the grill to swap hoods...
You can swap just the HD hood to a 1500, but the hood will stick out about 0.5" farther than the grille and look weird
so could you swap headlights, grille, and the hood would work?
Different mounting points for the grille, and to make the grille and headlights work, you'd need a Sierra bumper too (also different mounting points/brackets). Would take fab work to make that conversion...I'm sure it has been done by somewhere in RGV however.
so the GMC HD hood will fit on my chevy just stick out a little bit or do you mean the Chevy HD hood will fit but stick out?
No the chevy HD hood will stick out farther than the 1500 grille on a chevy 1500, and same goes for sierra. Not sure if they can be interchanged...I think the lines would be off.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 374 Guests (See full list)
