Title says it. For those of you who run an aftermarket stereo system, where on your 2007 through 2013 Silverado/Sierra firewall do you run your power wire through?
Do you drill a hole or use an already existing OEM grommet?
I cut a small slit in the main harness near the brake booster. Worked great for me as I ran my amps under the drivers seat. It is a little of a pain because the grommet is double thick.
i went under the floor on the passenger side. there's a factory grommet you can drill right through and don't have to worry about getting near any factory wires at all.
That is where I went through for my backup camera and nerf bar lighting. Just knocked one out and replaced it with a rubber grommet. good to go!!
I didn’t know there were holes in the floor pan. Are they meant to be a pass-through for vehicles with different options?
Using the floor grommets is absolutely a great idea because you have easy access from the top and the bottom and they are extremely easy to seal up once you are done passing through your cables. Contrast that to passing anything through the firewall, where it is always extremely difficult to seal the hole or grommet from leaks...
How do you provide protection for the cable running it under the truck?
Cover your cables in plastic split loom like the factory does and you won't have any problems at all – your cable runs will look like factory stuff and they will be very well protected...
Where exactly are these grommet holes under the truck?
pull back the carpet....
Or get under the truck and look about where your knees would be if you're sitting in the front seat...
  • 2 years later...
This sounds like an awesome idea.. i wish i would have saw this when i wired in my heated wipers.. amp and temporary sub going in next week.
Thanks all!
  • 4 years later...
Does anyone have a photo of  where these grommets area under the seat on the GMC sierra??  great idea, just would like to see where first, since my underbody has been sparyed
  • 2 years later...
In above pic you will see a black rubber grommet on drivers side and on passenger side it is a gray circle in color. I was sound insulating my truck some years ago. Hope this helps anyone interested?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
