Hey all
PharmZ71
Hey all.  Just wanted to say hey.  Graduated from college as a Pharmacist in May, and used my first bout with money to buy a '97 Cherry Condition..only 40k miles, Royal Blue Z71 from a fellow Pharmacist and I am in love with it.  Hope to be a part of a lot of discussion.
Hey Pharm....   My wife is a pharmacist too.  Very good profession.  Where do you work?  She's in a regional grocery store chain here in Michigan.  She used to work at another one in Upstate NY before she moved here.
Welcome.
-Matt
    • *Your
