Anyone have experience with Polk's soundbars?
Chris
I'm looking into those as an alternative to Bose. 1/3-1/5 the cost of the Bose.
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I would be using for my bedroom and I also consider my living room small. Maybe 15x20
Well its not for 5.1. It runs about $450. You run a fiber cable from the TV to the back and has a wireless sub
Poke around on Craigslist..you can put together a help of a system for $500. A good receiver will run a couple hundred bucks (HDMI and all), a sub for $50-100, and a couple hundred should buy some good bookshelves, a center, and a couple small surrounds.
A system like this should blow a soundbar out of the water any day, provided you research the specific model numbers of the units you pick up.
My thing is with my living room design and my entertainment center I'll have wires everywhere
This shows the small width of my living room and my entertainment center. You can see my door and the end of the room 2013-02-15_14-34-30_151_zpse47c9466.jpg
I have the surround sound speakers and sub, I just wanted something to put by the tv for a little better midrange quality. Oh and I need the receiver too.
For that style room a soundbar would work for getting better sound but will by no means replace a surround sound setup.
I have a Onkyo 7.1 surround sound in myroom, and absolutely love it. It was 4 hdmi's and a crap load of other inputs and outputs. It is a 1200 watt system, and i would put it up against sokme of the cheaper end bose systems without a question. Best part is, it was only $400 ish back in the day when i got it from circuit city.
Looking into the SurroundBar 6000IHT at first. Maybe 2 of them. Don't see much difference in the 6000 and 9000 system
The 9000 is 10 inches longer. But almost twice the cost
I bought it. It doesn't out perform my Sony wired setup. I will most likely take it back. I can't get it to cooperate with my TV via fiber optic cable, I don't have the fine adjustments like the Sony did (by fine I mean treble and bass). I can just adjust bar volume and sub volume. Not to mention my Sony had HDMI pass through and 3 HDMI video inputs that passed through to one output to the TV. So if I used the Sony system and the TV's inputs with optical or RCA out I had a total of 6 HDMI ports. Sound quality isn't as great. For me it was $400 poorly spent.
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
