Factory fog light issues
SarahsGMC
Both fog lights weren't working bulbs fine fuses fine so I hooked up a multimeter on driver side light plug it got up to .51 amps I crawl out from under truck and magically my passenger side is on but driver side still off... Now there's ice all over the backing of the lights and one of the prongs on the light seems to have a little rust could it be that? But that doesn't explain why magically the one light came back on. Could there be a wiring issue somewhere else? I'm only assuming this is a weather issue I just want to cover all my bases.
Sent from your truck via Tapatalk
I would guess something is loose/dirty
Sent from my SCH-I535 using Tapatalk 2
I am not sure why you would measure current flow(amps). Chances are you have a bad connection on the right side. That bad connection can be in one or more of the connections in the wires going to that fog light, as well as the socket itself, or even inside the actual bulb. You may find that the bulb is blown, but, it is only a break in the filament, and by shaking the bulb, it makes a connection, and "welds" itself back on, completing the circuit.
You should be testing for voltage at the connectors, not amps, or checking for continuity with either a continuity tester or an ohm meter. Disconnect battery before testing resistance with an ohm meter (or remove power from circuit).
Any time you get all lights in the circuit going out, it is not likely the bulbs. It is likely some single item that effects both bulbs at the same time. Try checking charging voltage as well. It may be overcharging, that will take out bulbs with very little symptom.
well i pulled the working bulb and plugged it into the driver side and it worked so it looks like its a bulb issue, they look to be factory bulbs so this doesnt surprise me
    • Thanks, all. It sounds like keeping the software "as is" is the best course of action.
    • https://en.wikipedia.org/wiki/Overengineering   Excerpt from the above link: (BTW the above is a 90 second read)   [Quote]   A story about very precise engineering is given in the 1858 story The Deacon's Masterpiece or, the Wonderful "One-hoss Shay": A Logical Story by Oliver Wendell Holmes Sr., which tells of a carriage (one-horse shay) Because it had been engineered so that no single piece failed first – no piece was over-engineered relative to the others, and they thus all collapsed at the same time. A similar quote by Ferdinand Porsche claimed "the perfect race car crosses the finish line in first place and immediately falls into pieces."[5]   [End Quote}   By Engineering's  own definition then; the AFM and Torque Converters, 4-5-6 clutch assembly of the 6L80E, and a dozen other common chronic parts and systems failures are "UNDER ENGINEERED". And by their own definition done so with INTENT. Ya can't have it both ways OEM's.
    • Everything you need to know..... https://www.gm-trucks.com/forums/topic/198157-2014-2017-dl8-dl3-towing-mirror-upgrade-–-mirrors-explained/
    • I was in Utah this week attempting a bow hunt in the Wasatch mountains with friends.  On the evening of the first hunt, making my way across a ridge to a friends camp, the upper control arm on the driver's side separated, the CV axle got trashed, and the wheel was dang near at a 45 degree angle to the ground.  I was able to get it towed off the mountain and into town about 3:00 am, and spent the remainder of the night in an O'Reilly's parking lot.  Luckily, there was a Chevrolet dealership not to far away so I was able to get to the dealership and pick up a new CV and UCA.  It would have been a few days before they could have gotten to the truck and I brought tools with me on hunt since it was a two day drive to get there, so I did the repairs myself in the O'Reilly's parking lot.      What's interesting is that the UCA ball joint didn't break, it just popped out of the bottom of the UCA.  There was VERY LITTLE evidence of grease on the ball joint or in the socket, and you could see where the ball joint had warbled out part of the socket over time.  I guess that's what happens over 186K miles of use :)   Big Kudos to O'Reilly's for letting me work on the truck in their parking lot.  However, they made a $150+ off of me from the purchase of various tools, so I guess it was in their best interest anyways :)   Getting towed off the mountain.   UCA Ball Joint Socket   Trashed CV   Suspension disconnected and UCA and CV Removed   New UCA and CV installed with the suspension buttoned up.
    • My family still laughs at me when they see me drive up in the minivan. Same with less than a V-8 truck. It helps that I have choices. I don’t think I could only have a minivan as the one and only vehicle as much as I like it. And I wouldn’t pass up a good buy on an older V-8 reg cab GM truck. Could you live Raven as the only ride?
