JL4 RPO Code?
Hello Guys, when it says: Except Active brake control, (JL4), it means that your
vehicle doesn't have JL4. Right! The reason why I'm asking this question
is because I went to the dealer and they sold me the front disc brake pad kit part # AcDelco 171-0975 or OEM GM 25918341 which it's for vehicle with JL4. But looking in the glove compartment at the service parts id sticker, i don't see the JL4 code on there. what i can see is the JF7. My question is: Do they give me the wrong brake pads for my truck. Thanks.
What kind of truck?
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
What kind of truck? Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
2005 LS Silverado Stepside or Sportside 1500 V8-323ci 5.3L Reg. Cab. 4x4
Was this issue posted on silveradoss.com as well?
Magic Wheels,
Has your question been answered? Feel free to contact me as well with the last eight of your VIN if you need additional assistance. Thank you.
Tricia, GM Customer Service.
The vin # is 5Z310976
JL4 was not an option on any GM pickup truck until 2007 current body style therefore, you don't have it.
ACDelco Parts Catalog
PAD KIT-FRT DISC BRK
Part Number: 171-0974 = 25910431 Product Notes:
Front Disc Brake Pad Kit
Crew Cab; 7, 000 Lb Vac Power Brk (JF3); Except Active brake control, (JL4)
Ext Cab; 6, 400 Lb Vac Power Brk (JF7); Except Active brake control, (JL4)
Reg cab; 6, 400 Lb Vac Power Brk (JF7); Except Active brake control, (JL4)
Per Vehicle: 1; Years: 2005-2005
PAD KIT,FRT DISC BRK
Part Number: 171-0975 = 19257667 Product Notes:
Crew Cab; 7, 000 Lb Vac Power Brk (JF3); Active Brake Control (JL4)
Ext Cab; 6, 400 Lb Vac Power Brk (JF7); Active Brake Control (JL4)
Reg cab; 6, 400 Lb Vac Power Brk (JF7); Active Brake Control (JL4)
  • 9 months later...
What is the difference between JL4 pads and regular pads?
The reason I'm asking is because by mistake I purchased non-JL4 pads for a Tahoe that has JL4... they appear the same but what would be the problem if I installed them?
Replacement pads there seems to be no difference. If using an ACDelco pad, the Durastop replacements are the same either JL4 or not. The OE pads are different, but I am not sure why.
Although ACDelco makes both a non-JL4 version (ACDelco part# 17D1367CH and GM part# 19241581) and a JL4 version for double the price (ACDelco part# 1711074 and GM part# 22742382) I just installed the non JL4 version and they fit no problem.
That other part number is the OE pad. 19241581 is the Durastop line. Even the non-JL4 OE pad is double the price.
  • 2 years later...
My truck has both JF3 and JL4 on the service parts sticker. It's a 2008 Silverado 1500. Is it safe to assume that I do, in fact, have active brake control?
    ar0517
    ar0517
  • Who's Online   3 Members, 0 Anonymous, 660 Guests (See full list)
