Need help with custom wheel
Pounder
Im looking to put some 20 inch wheels on my 2012 Sierra CC. I have chosen to purchase some chrome eagle alloy 050 with cooper discover ht plus in a 275 60 20. Does anyone think I will have any trouble with clearance issues with this set up? I will be adding a rc 2 inch level and the rims have a +25 mm offset. I really dont want any rubbing what so ever. Would I be better off with a different offset or maybe a 275 55 20? I do not want the tires to stick outof the wheel well, would like them flush with the fenders. Just looking for a little guidance as I have never run aftermarket rims before and want to makea good decision the first time. Any help is appreciated.
I have the tires you want in a 275/55R20. Unless you have a leveling kit the 275/60R20 will rub. Its just too tall for stock height. I run the 55 with a level and a +22 offset. The width of the 275 looks perfect in my fender but I have an 04.
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I was concerned that going to a 9 inch wheel and a 25 mm offset may cause the tires to stick out from the past the fenders? I will be adding a 2 inch level to accomadate the 33 inch tire. My only hestitation was when I went to order the leveling kit the parts guy figured that size of tire would be to big. I was reassured when ordering these rims and tires that a 275 60 20 would fit with a 2 inch level and that the 20×9 rim with the 25mm offset would sit under the truck fairly close to stock
My wheels are 8.5" but we also have 2 different suspension types. Mine are 20x8.5 with a +22 offset on 275/55R20. The only change I would make is to go to a 305/50R20. If it rubs on the front stagger to the 305 on the rear 275 up front. But you should be fine. That's the tire I originally looked at and they test fitted for me
Thats good to hear. I appreciate everyones replies, it can be a little intimidating buying aftermarket rims when you dont really understood how the offset and back spacing all comes into play. I just wanted to make sure I was going to get the fit/look I wanted with out any tire rub. I still may decide to put the 275 55 20 on instead of the 275 60. Is there any advantage to a higher sidewall or is it just personal preference.? Would the 33 look better? I also stumbled across a site that explains the offset and back spacing really well. (for those that are less familar with it)
https://www.rsracing.com/tech-wheel.html#backspace
Well you will love the tires. Here is how the 275/55R20 with a 2.5" level. How they fill the wheel well in height and width
That looks really good that is exactly what I'm after. Sits nice under the truck. Thanks for the close up pictures.
Those are the H/T plus and I have about 13k on them
The 60's should fit. If you can have them test fit it. I was showing how mine for and how the width was in the fender
I read alot of good reviews on the ht plus tires. Some guys are claiming 60 k no problem I even saw one person say they got 90k on a set. I Was surprised at how reasonable the price was on them, 200.00 a tire not to bad for 20's. I believe the total price for rims and tires is 2500.00 with tax and wheel sensors. I'm hoping to recoup some cash out of my stock wheels. They have 6000 k on them and were never run in the winter. I thinking off listing them at a1000 for the set.
I don't see me getting that much out of mine. I like to slide the rear out
I wasnt sure what they would be worth. I have seen them advertised for anywhere between 600 to 1200. In northern BC most everyone runs a second set of wheels for the winters we have (mandatory to have a straight winter tire for highway travel). I should have no problem selling them for a fair price.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
