Third Brake Light Wiring on 2003?
There appears to be two wires on a plug that contains four total on the end where the third brake light and cargo lamps are.  A black and light blue appear to lead to a copper strip that runs beneath the stops lamps and the other two wires appear to lead to the cargo lamp.  On the brake pedal end, there is a plug with six wires..
I have two sets of install instructions that requires you to decide if you have a 1- or 2-wire connection to the third brake lamps.
If anyone has any ideas on a 2003, let me know.
Thanks
I am checking the 2000 helms manual dont know if ill be able to find it but ill look and see
only thing i found was the black wire is the ground
Tx, don't know whether this really helps you, but I know the light blue (on my '03) is for the center high-mount third brake light.  I have one on the hitch wiring harness that is there to connect (splice, although it is in a connector of some sort) your topper center high-mount light, etc.
Can't find any info right now on the black - it may be a ground, like Ryan said.  You can always fire up the truck, and get out the multi-meter and have someone start turning on lights, signals, etc.  My topper appears to be a 1-wire, as I use only the blue (but I haven't wired the topper to the '03 yet ) .
Maybe I'm missing some info here, but GM has done a pretty poor job of providing clear wiring instructions w/ their various harnesses.  :wtf:
everything for the lights in the helms manual stated the black was ground
Okay...I think y'all got it!   I am adding the do-thingy that flashes the third brake light. Someone else asked about it and I got interested and bought one.  I will let you know how it goes today.
Thanks again.
    HWN808
    HWN808
  • Who's Online   3 Members, 0 Anonymous, 594 Guests (See full list)
