FREE - cab steps for crew cab half ton
THese came off of my 07 Silverado Classic crew cab. They will fit 03-07 half ton crews, and possibly 99-07 1500HD, 2500, 2500HD, or 3500s. Still might even fit an 07+ model. They hung kinda low on my 1500 so they will probably fit the HDs, but Im not sure to be honest. But, the price is good enough that you can get them and try them. If they don't work, you haven't lost anything but the gas to come get them. I only took them off because I didn't like the look of them. They have a little surface rust, but still feel solid. Come get em if you want em.
Table not included. Paint can, maybe.
Thx... too far, as I already have something similar but wanted "spares".
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
