1990 gmc sierra crank but not starting.
Im possibly trading my car for a 1990 gmc sierra ext cab truck. Its not running, this boy tells me it has a rebuilt motor which i believe we looked and it looks rebuilt. But the problem is it cranks but wont start, it is getting fuel, fuel pump works, it has a new distributor and module, so could it be the coil? We unhooked battery to reset the computer as well, so just trying to see if easy fix or what.
Has the truck ever run since the rebuild? Did you check for spark at the plugs? First thing to check on the GM HEI ignition is the rotor inside the distributor cap. Take the rotor off, and turn it over to check out the underside. If you see any black on the underside of the rotor near the middle, replace the rotor and try to start again.
Anything other than that will require more information from you on what you have checked for, or when did engine stop starting.
Yes it has ran since rebuild.new cap and rotor i checked that.he kept saying something about a wire.well i looked it over and the wire that plugs into the module was unplugged so i plugged it in and it is getting fuel now and i checked for spark at the plugs and nothing thats why im thinking.so if coil doesnt do it whats next?thnx.
If the module was unplugged you have to ask yourself how did that happen. There is another pair of wires inside the distributor that go the pick-up coil. Fairly common for those wires to break where they come out of the pick-up coil. A gentle pull on the wires will show you if they are broken. You should be able to locate instructions online on how to check the module and how to check the coil using an ohmmeter. I don't recall the numbers, but, it will take you just as long as it would take me to find them.
By the way are the wires your talking about go into the distributor or plug into the module next to the plug for the fuel.im not going to see it till next weekend so i want to know what all i need to trace down thnx.
Inside the distributor. The module has wires connected at both ends, one end has two wires, that connect to the pickup coil also inside the distributor. Those wires.
When you said the module was disconnected, you were talking about the part that bolts to the base of the distributor inside the cap aren't you? Your comment about fuel when talking about the wire has me thinking we are not talking about the same part.
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 686 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
