1996 GMC Sierra
Rawness100
Hi. I have a question. My truck( gmc Sierra 96) was messing up.High rpm,jerking back when you drive. It's an automatic. We cleaned the gas tank and the fuel pump. Checked the vacuum valves and the alternator the tranny. And it's still doing the same thing. So anybody have an idea what it could be?
i stumbled on your question ,,
you received no answer because your complaint is not clear at all,
transmission concerns are not easily diagnosed especially on the internet ...
take the truck to a shop and have it road tested by a transmission specialist
if you live near Lloydminster PM me
We took it the shop twice and they didn't find anything wrong with it. They said maybe a dirty fuel filter.
But we changed it and cleaned the fuel pump and gas tank.
(Maybe the injectors)
When you drive it for awhile its fine,then when it idles it starts rumbling (not stalling) and then you go again an while your driving its like jerking back and the rpm goes high. I can't explain but I'm not close to Lloyd minister.
Check the transmission fluid level. When was the last time the transmission filter and fluid have been changed?
I'm not sure when it was changed. We bought it off a used car dealer guy in laronge. It worked for 2 days we didn't want to chance driving it back to the shop as we are isolated. I know the transmission oil is on "hot" and half an inch over the limit. When it idles its still on hot but goes down a little bit. Does that make sense?
I would check the cap and rotor. Check the distributor shaft for sloppiness.
Sent from my SGH-I747M using Tapatalk 4 Beta
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
