Memorial Day Special and Patriot Wax Raffle!
“Today is the day we put aside to remember fallen heroes and to pray that no heroes will ever have to die for us again. It's a day of thanks for the valor of others, a day to remember the splendor of America and those of her children who rest in this cemetery and others. It's a day to be with the family and remember."-Ronald Reagan
Memorial Day is a day that those of us at Adam's take very seriously. It's a day to remember the very bravest among us, those that chose to give their lives in defense of our freedoms. To honor this sacrifice we are doing a little something extra with this years Memorial Day promotion exclusive to the forums...
We are going to raffle off one of our Limited Edition Patriot Wax Kits to a lucky customer.
Here's how to enter:
  • Place an order between noon MST 5/23 and 11:59pm MST 5/27 on AdamsPolishes.com.
  • The order total must be greater than $50 including taxes, shipping, and any discounts.
  • Add the comment "IN REMEMBRANCE OF ALL THE FALLEN HEROES" in the order notes.
If your order meets all 3 requirements it will be entered into the drawing for the Patriot Wax Kit. Tuesday after the holiday we will enter all the customer ID's into a randomizer and select one lucky winner. YOUR ORDER MUST MEET ALL 3 REQUIREMENTS TO BE ENTERED.
Adam's will add all $250 of the retail value of the kit to our donations made to the Intrepid Fallen Heroes Fund and include the winners name on the donation list for our contributions.
Sorry to our friends in Canada, you are not eligible for the raffle, but we have the same shipping promotion just for you guys on AdamsPolishes.ca
CLICK THE PICTURE BELOW TO START SHOPPING.
Congratulations to Rayce Brossette, the lucky winner who was chosen at random to win a Patriot Wax! Thanks to everyone who participated. More importantly thanks to all those brave men in women who have served and continue to serve our great nation.
    Smitty462
    Smitty462
  • Who's Online   5 Members, 1 Anonymous, 698 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
