Xbox One...
  • Replies 267
I don't see how you have that much time
I have no life
ehhh it happens. Better than dealing drugs and such haha
Riiigght because that makes no money...
Well I 100%'d GTA 5 today. Only took about 77 hours. Time to do multiplayer, start on GTA 5 PS4, Halo MCC, and replay The Last of Us
Knock MCC down the list. Several sessions the game didn't save when I told it to. Had to redo many missions( in 2 and 4). They just released another patch but I wouldn't trust it, that said they were focusing on the MP side of the bugs.
Have been mediocre at best with titanfall(got the complete edition for $13 during the xbox live sale a few weeks ago). Started playing frontier guard or whatever(hoarde mode) and was just on a team that was 32 points from scoring a perfect 2000 and I was the top scorer. Maybe I should quit while I'm on top :lol:
I just unlocked 2 halo ce achievements while watching netflix. Havent played it in a couple weeks. Havent wven beat halo ce yet got the achievement for beating it
I recommending playing about halfway through one, watching the YouTube videos with all the terminals, then doing the same for 2 and 4. Doing that and playing them all back to back everything makes note sense. 4 is still kind of lacking story wise.
The librarian having The bad guy "stored" to guide humans down the right path makes zero sense. Like he would wake up and suddenly change his mind because.....reasons
See halo 4 campaign was my favorite, except maybe the original halo. The original halo campaign was just groundbreaking and so much fun. Where you're in the room and the flood come in is awesome.
I have seen people online complaining about the loadouts and how they should be removed in h5, saying they're CODish and they're for noobs. I didn't realize it was that hard to go to a playlist without loadouts? Lol maybe I'm just stupid.
I'm gonna get Halo for Christmas hopefully, if not I'll just buy it myself.
Has anyone played Shadow of Mordor? I thought about getting it.
What happened to Xbox Live today? It didn't bother me much but my grandson got an Xbox One today and he and his Dad spent all day trying to get an account set up and go through all the updates. They kept calling to see if I could get on but I couldn't until the middle of the afternoon and then later in the day it was off again. I'll bet there were a lot of upset kids today not to mention their parents.
Mike
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 491 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
