White1500's 2000 extended cab intro
For what it's worth, in all the miles I've put on my truck I have not noticed a difference between castrol gtx and castrol high mileage. The castrol full synthetic did great for performance and gas mileage but I got to where I was burning through it too quick to even bother with it
  • Replies 37
Also on the agenda is a front brake pad change as they have been squealing a little lately. I will use ceramic ACdelcos just like on the rear, which have been impeccable and put out extremely low dust.
And planned is a tire rotation because I like to do it every 5,000 miles.
Otherwise nothing else to report besides a check engine light for one day but I think it was due to the change engine oil light that has been flashing forever because I have forgotten to reset it.
And I want to buy the center console lid soon since it had been damaged for a while and was broken for good when someone trifled through my truck back in August... (accidentally left a door unlocked over night).
http://m.ebay.com/itm/200825489127?nav=SEARCH&sbk=1
I want to go with the leatherette material since the cloth looks like sht over from using it as an arm rest for 11 years(!).
I don't know if I experience an actual difference while using high mileage oil but I like the piece of mind, and the price isn't bad.
And she needs less than a quart every 4-5000 miles due to burning and leaks. Not too bad at this point in time.
I almost forgot to mention that I'm even considering cycling to work since its only 3 miles away. That would reduce weekly miles by 6 per day, leaving Saturday as the main contributor at around 60 on average for that day alone.
I know that 6 per day isn't that big of a deal but its the cold starts and short drives that bug me. Aside from on Saturday, she rarely gets all the way to the proper operating temperature.
Oil was changed today at a tad over 216,000. Everything went smooth and it was a relief to see that the filter I took off was the one ending in 61!
Not too much weight but I could certainly feel it. When on the street I went through the gears but used drive on the freeway when up to speed.
For some reason tow/haul mode wasn't working that day even though it had not too long ago.
And I think the rear end squatted an inch or so, not bad.
You'll be healthier too!
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 498 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
