i bought mine from LMCtruck.com if you go to quick order the part number is 39-8026 ( enter with dash) its 99.95 probly the same as ebay page above. ( material wise)
instillation is a breeze
The switch itself still runs around $18.00. Cut a hole and save some bucks.
P/N 15947842
Thanks for all the responses! I went with Ebay Pknitty86 referred = $72.99 out the door.
  • 3 months later...
May I ask what is probably a stupid question, If you dont have the DIC (mine just has the little push stem in the dash bezel 2012 GMC) You can buy the package listed here and install with no programming and have all thye functions of a factory installed DIC ? Does the wiring for the new switch already exist behind the dash bezel?
Thanks
Thanks
Yes, yes, and yes
    • *Your
