6.2L L9H Sticky
TahoeL9H
Hi folks,
I had to join for the L9H Sticky..
I have a 2009 Tahoe LTZ 4WD, 6.2L L9H that is my old man hot rod... had to have something exciting to drive since i quit drag racing. Great vehicle, just use it for weekend & trips.. It is a hoot to whip up on the Goat Trucks & the TuRD's with a soccer mom Tahoe :)
And it is still stock.. Gonna due a CAI, Exhaust & tune on her shortly.. :thumbs:
Work truck is a GMC Sierra SLE CC 4WD Vortecmax. this has been the best truck I have ever owned. I work it's butt off & it never quits..haul up to a JD tractor with front end loader & 6' shredder.. no problems..
Anyway, just wanted to say thanks for a very nice website & a wealth of info..
Good to be here,
TahowL9H
I guess you did a 6.2 swap into the Tahoe? Never heard of one coming stock with the 6.2.
The 6.2 was an option for 2009
Welcome aboard
Welcome aboard
Yep came in the Avalanche too for a short time as an option. They are hard to find used. Think most people had no idea and didn't even ask about a 6.2 Tahoe or Avalanche. Most people don't join vehicle forums and aren't kept up to date
Thanks for the welcomes & replies... I think I can learn a lot from this site.. great to have a specific 6.2 section..
They are pretty rare & I knew about them from a friend who sells Chevy trucks, but never thought about it until I retired & started looking for something different to drive.. I have a restored IH Scout, but it is not good for long trips & has no AC.. kinda a garage queen..
I actually was going to buy an 09 Vette, but being old, wide & a bit arthritic, i started looking for something easier to get in & out of but had good performance.. i had an 03 Z71 Tahoe that I really liked, then the light bulb went off & i remembered the 09 Tahoe was available with the 6.2, so i started a search.
Well after about 6-8 months i found one with 35,000 miles on it, made the dealer an offer & had it shipped down here to South Texas..
One of the reasons you don't see them very often is you had to get the LTZ package to get the 6.2 option, so the price was very close to a Denali..
Chevy made 620 of them total... This one is Champagne Silver with Cashmere leather.. nice & cool down here.. 104 air temp today.
It really is a hoot to drive,
TahoeL9h.
Champagne silver? Should be Silver Birch. We had an 08
Any photos of your Tahoe? I have only heard of one other person with the 6.2 (it was a gm exec vehicle)
Nope, not Silver birch, had 3 of those, a Sebring Silver Corvette, this Officially is Gold Mist Metallic, but I have been told to call it Champagne Silver.. If you would like to debate the point, I will direct you to "She That Knows All" but be forewarned, you will lose :)
I will try to upload some pictures later.
TahoeL9H
Cannot upload pictures easily.. Says file is either too big or does not recognize Picasa files.
Don't have time to mess with it right now..
Thanks,,
TahoeL9H
Welcome! Try using the tapatalk app if you have a smart phone, it works really well. If not u can always drag them into paint on your computer and resize about 50% depending what quality the camera is.
Trying again to upload some photos.. i guess i downsized them enough.. I do not see size restrictions, what are they??
Last shot with the snow is from the dealer I bought it from or maybe a GM ad..
Thanks for the interest
TahoeL9H
Looks good! Definitely not silver birch :)
Ryan
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
