Dont have cold AC
So go to recharge the system it has a high presure on it in the red . The compresser is working and the lines are really cold but all I get is coolish air coming out .
I might have blender door problems not sure would that cuase the issues .
It seems my system is charge . I am not getting cold air.
Advice?
Was it working before the last charge? Yes blender door issues can cause havic on GMs.
Other thoughts....is the compressor cycling? Even if its a long cycle you might catch it when its powering down which will show high pressure readings.
THis might sound odd, but put a can of coolant on the fill line and start the truck when its cold, put the ac on max and two minutes later open the can and put a little in. Just a min or so, not enough to hurt anythingb or raise the pressure much. close off the can and disconnect the guages and then reconnect gauges and check again.
Ive seen this work in similar situations, maybe air in the line or something. Or is its low on coolant
I had an issue similar once ended up being the damper control for the dual zone.
I notice my driver side blend door acuator is not working . So I tried disconecting the black cable to recalibrate nonthing did not move. So I took it off and opened it up looked fine . Turned it on to see if the gears would spin they spined for a while and stoped . Then I tried moving the switch up and down to see if the gears would move . They would not move .
So I turned the knob the acuator suppose to turn to cold to see if the AC would work . It seemed to work I will know on a drive latter . Do I need a new blend door acuator becuase the gears look fine just does not seem to want to work when I move the switch up and down from cold to hot. Is there a fuse for the passager blend door acuator ?
no to a fuse ....yes to computor controlled system,,,,data on a scanner will show position of doors
no guessing ,,,,!!!!
have system recovered ,see how much comes out ,,,,,,put back in the required amount ,,,,,,no guessing or assumptions ya hear !!!? lol
oh and now my thermostat is not working again and I just changed it this last winter ...... starting to really dislike the gm 800s for realibility on hvac controls and other little things.
Been a long while since I've been up here, but I just went thru this with my '07 Sierra about 2 months ago. Air was running warm, cooling fans weren't coming on, etc., so I added a can of 134, and some leak dye. That lasted about a week, and it went bad again.
Went to my tech-buddy, and he scanned everything, commanded everything on and off, etc., and it was good. We couldn't see anything as far as leakage from the dye, so he suggested a can of Super Seal. Got it at Advance Auto, for about 25 bucks.
We evacuated everything (not much came out), put in 1 can of 134, the sealer, and the second can of coolant, and away she went. The fans came on, the air was super cool, and it seems to have worked. Had 34-36 degrees at the vent.
I've since traded the ol' girl in on a 2013 Silverado and LOVE it. Kinda gutless with the 3:42 gears, but I'm not towing anymore, so it's not a concern. Now it's time load up on the accessories!!
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
