I made it!!!!!!
Zane
Well Bill, I think that you are really close. If you were to send this out four more times you will be a senior member. Then you get an AARP card.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
