Newbie here and to Chevy
firemedic
Hey all just wanted to stop in and say hello I am new here and new to chevy. I am putting back together a 1997 Z71 with a vortec 350, with 188k miles on her. any adivce will be much needed.
Be Safe
:jester:
Welcome to the site FireMedic. :thumb: I am sure you will find the members here more then willing to answer any question you might have.  There are some quite knowledgeable people on the site...
:jester:
K1500, yes it is one of my many professions, I am also a claims adjuster, and a Fire Serivice Instructor and EMT Instructor.
city slicker. as I said above I am a claims adjuster and I made a sweet deal on the truck that did not fit under the bridge. Having a new top door fender and hood put on her and new set of paint. by the time she is done I will have less than 2k in her.
Be safe :cheers:
Be safe :D
Alright cool , I am a volunteer firefighter/First responder (one step below emt) have been for almost 4 yrs  :D
Sorry, I never saw that anywhere ???
Sounds like you will have your moneys worth. :D  :D
