I need suggestions!!
I have a 95 gmc sierra extend cab long bed. I want to add stuff to her. Cab corners are gone so I want to fix them. But also I want to undercoat the frame. Plus I want some mods to add HP and MPG. Headers? Cold air intake? Throttle body spacer? Any ideas?
Black Bear Tune.
Don't believe BBP tunes the pre gmt800 trucks. Check on that
Ryan
They do 96 and newer. I think 98 is for the live tune
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
