What Size Tires Comparable to 33X13
SSSilverado23
Right now im running some tires that are 33x13'' tires. I want to switch to a MT tire and change brands. These are Falkens and I want some Nitto Trail Grapps. I was curious if I could go with a 34 or 35'' tall tire and if I go down in width?
I was thinking the 295/70/18's which are a 34.57x11.93. So they are over an inch skinnier and an inch and a half taller. Let me know if my thinking is correct if this wont work.
For reference, my truck is a 06 2500HD with 4'' lift on the front and 2'' in the rear. I would like the biggest tire that will fit. Thanks!
Depending on the wheels I would think those tires would work.
What kind of offset would you think? I may be replacing my rims as well.
Sent from my SCH-I605 using Xparent Red Tapatalk 2
Something in the 0 to + 20 range. I ran pretty much the same size tire you currently have on aftermarket wheels on my 03 HD with just a crank. I did a little hammering in the fenders but they still rubbed a little every now and then, so I think with 4" of lift you can pull it off with minimal rubbing.
Not much experience in 2500HD's, it should fit depending on wheel offset. Might rub at full lock
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
Im thinking about 33x12.50 or 35x12.50 now. Not sure the 35's would fit though. Might be to much...
You could always have them test fitted when you go to buy. Then if tje 35's dont fit settle for the 33's
You could always have them test fitted when you go to buy. Then if tje 35's dont fit settle for the 33's Sent from my Samsung GS4 using Xparent Red Tapatalk 2
Ya only issue is that I buy online. Discount tire direct. So that really isnt possible. Thats the cheapest place I have found.
Some places price match. Call around and check. Doesn't hurt to find out
Ill try that. I tried with discount tire locally last time and they wouldnt compete with direct. Ill check other places.
My local DT will match their online prices.
Directs? Because mine told me they were different companies amd couldnt compete with direct. If it were the regular discount tire site they would.
Yeah. Discount were I'm at will compete with anyone's shipped price. I "wheel and deal", pun intended, anytime I buy wheels/ tires from them, which is more often than I'd like.
    TopBo
    TopBo
  • Who's Online   1 Member, 0 Anonymous, 3,245 Guests (See full list)
