Dash Camera????
doverarjim
@ OP
I've got the I-tronic in my truck.
The cam broke down due to the heat in the car in the summer.
In my company truck I've got a cheap camera like this:
http://www.amazon.ca/Monitor-Dashboard-VEHICLE-Accident-RECORDER/dp/B008912U82/ref=sr_1_4?ie=UTF8&qid=1376433982&sr=8-4&keywords=dash+cam
Still works. Shuts himself off when it gets to hot.
The quality of the pictures is not so perfect. But if you need the cam for 'just in case' recording it'll do fine.
If you wanna record the sight you better go with GoPro or BlackVue or even I-tronics.
Just turn the cam off when the truck is sitting in the hot summer sun.
so long
j-ten-ner
The heat definitely gets to them. I always take mine out of my truck during the day or they won't last more than a few days of a Texas summer. In mine the batteries have swelled until they broke some of the circuitry. I've used the same one that you use in your company truck and it's good enough for CYA. Now I'm running this: http://www.amazon.com/2-5-inch-Vehicle-Recorder-Dashboard-Camcorder/dp/B0053DDNW6/ref=sr_1_1?ie=UTF8&qid=1376444745&sr=8-1&keywords=dash+cam . It's cheaper, works the same as the other one and records at the same quality. They're so cheap that I keep backups on hand!
The only thing about the cheap cams is that it is hard or even impossible to read the license plates.
I mean if the other driver takes of and I'm not in any state of "shock" I can write the plate# down.
That's why I went with the I-tronic. Nice recording, GPS, G-sensor etc. But the audio wasn't very good. Sometimes it is good to have the audio recorded as well...
The heat killed it.
I'm thinking about to give the BlackVue a try.
http://www.blackvue.ca/
Given that I watch the temperature...lol...or I "customize" the cam a little.
so long
j-ten-ner
@ OP
so long
j-ten-ner
Did you just recommend a dash cam that you said broke from interior heat? Did I miss something?
Heat is a big issue for dash cams. You can read about it all over the I-net.
And, yes you missed to read the last sentence.
so long
j-ten-ner
I have a hero 2 go-pro that tags along with me on long trips, I set it down to 720p to save memory. Flick it on whenever traffic is heavy or I see something weird. Or bad driver.
Another idea is to get a windshield mount for your phone. Just plug it in during driving so no battery worries. Delete the file at your destination if nothing happens. And you can do most of the set uo and delete walking to and from the car so no real delay when you get in it
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,335 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
