Since I'm still a student, I can't really budget for rims now but what are your guys' opinions on wheel spacers, I just want my truck to have a little stance. Anybody got these? Recommendations?
Just get an wider rim with wide tires. Unless you are that tight on money and need a quick mod.
Ya I've read that they can screw up axle components and ball joints, on the rims do you look for a negative offset for wider stance or how does that work?
If I remember right, +31 is factory offset. So as you go towards 0 and into negatives they will stick out further. A friend of mine used to run the spacers so he could fit bigger tires. They ended up being a pain so he ditched them. I'd wait until you can do new wheels and tires, you'll be happiest with a new setup I think.
definatley not a good idea to run them.. if you have no money then dont worry about modding your truck. save it for gas
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
