How-To: DL8 to DL3 Mirror Mod GMT900.
This is my tutorial on the DL8 to DL3 mod. The mirrors I installed were DL8's with DL3 glass. In the tutorial I have the information on how to wire in the auto dim so that feature works with the auto dim rear view mirror.
Here is the link to the tutorial:
https://docs.google.com/file/d/0B2-2GFXxDXpmbDYweUk1bmJHU2M/edit?usp=sharing
The quality of pictures does get diminished some through the Google sharing, but if you do want higher quality pictures, feel free to contact me. Also if you have any questions, feel free to ask. I do enjoy having the turn signals and the auto dimming drivers mirror. I also outline different places to look to see if the wiring for the turn signals is there from previous research.
It's a good right up but to identify if you are able to do this mod with DL8 to DL3 just look at the RPO codes in the glove box. DL8 will allow DL3 mirror mod. I don't know if the other DL codes 2, 4, 5, 6 and 7 for the LS and WT model trucks but most wont be able to use the DL3's.
I wish you could find a way to make the power fold work with the Key FOB lock/unlock feature. I viewed a video on YouTube but he does not explain it.
Thanks, and I'm not sure on the other DL codes. Another note is the biggest thing on getting fully functioning DL3's is the wiring that comes in the truck. My truck is a hardwired style switch whereas the one that is plug and play on power folding is a databus style plug. That's why I only did the DL3 glass in DL8 housings because I didn't want the added cost of getting it to work like factory and the main features I wanted was auto dimming drivers and turn signals.
As for the folding and unfolding with the key fob, that I have no idea on how that works since I don't have power folding mirrors.
For more information and one of the threads that helped me decide the DL3 glass in DL8 housings, here is a link to that thread:
http://www.gm-trucks.com/forums/topic/107062-adding-power-folding-mirrors/
Also a quote from that thread:
I was interested in this and found some very good info here:
http://performancetrucks.net/forums/showthread.php?t=441341
Basically
to paraphrase that thread, for the easy swap your current window
switches have to be the style with the included databus module
(typically the uplevel trims, ie Sierra SLT or Silverado LTZ) instead of
the standard hardwired switch panels. If you have those databus style
the swap is apparently as easy as adding the DL3 mirrors, swapping in a
driver-side and passenger-side switch panel from a truck that had DL3's,
plugging in the connectors, and everything is likely to be plug-n-play
and there's no need to get anything reflashed. If you buy new switches
that didn't come from a truck with the DL3's, or only buy a used
driver-side switch and not the passenger-side too, then they apparently
have to re-flash your BCM but the rest of the install is still just as
easy.
However if you have the hardwired style, while it's still
theoretically possible to upgrade to the DL3's (read post #9 in the link
above), it involves all new wiring harnesses, switches, upgrading the
BCM, rewiring the rear window switches, ordering a new XM receiver (no
joke), some knowledgeable flashing and programming, and so forth. In
other words, it looks to be very complicated and probably expensive, so I
don't know if it's worth it. Unfortunately I'm in this boat as my
switches are the the hardwired style.
For identification purposes, this is the hardwired style of switch:
And this is the style with the databus module (note the different types of connections):attachicon.gifdatabus3.jpgattachicon.gifdatabus4.jpg
From
what I've read, you can identify the databus style without seeing the
connections by that larger circle mirror adjustment pad and the
half-circle notched mirror selector button under it, versus the smaller
mirror adjustment pad and rocker-style selector switch on the hardwired
style. But if you want to double-check (which I did just in case I was
lucky enough that mine were somehow the databus style even though they
look like the hardwired ones), it only takes a minute to disassemble the
door enough to remove the switch and see what type of connectors you
have.
Yeah we both have hardwired switches and I'm not about to spend that type of money just for factory. I saw where someone had figured out how to run some timer relays liked they use in aftermarket remote start kits to set the mirrors to fold in and out using the Key FOB like I showed above.
I just need to find someone who knows what parts are needed and a wiring diagram to do it all.
I can understand that, I'll look through and see if I can find the bookmarked write ups with some of the diagrams for getting the power fold to work by hard wiring. I'll PM you it when I find them. Someone on here might know of the parts as well.
I know if you go stock the cost can be from 500-800 bucks.
Here is a photo of the switches he used from another site but the guy didn't post a how to. He set it to open and close with the FOB.
Hopefully someone can chime in on the aspect of making it fold and unfold via the fob. That is a pretty sweet addition.
Gentlemen, I am in the same boat as you with my 2013 Silverado as I have purchased a set of used DL3 mirrors that included the databus switches thinking the plug and play swap with my current DL8 mirrors would be a piece of cake. NOT!
I did find this on another site but have not tried it, as me and wiring or electricity of any type do not get along. http://www.silveradosierra.com/how-to-articles/dl8-to-fully-function-dl3-t125969.html
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,295 Guests (See full list)
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
