car wash/wax problem??
My truck is all streaked and horrible.
I had it waxed---it looked great.
I took it to the carwash and the damn thing snagged my mirror and stopped, leaving me covered in soap.
I took it to the self serve bay and rinsed it.
I have been through the carwash x 2 now
It sat outside in torrential downpours for 2 days.
It is still streaked and horrible.
Is it the wax causing a problem?
Or is it the damn soap thing even though I rinsed it?
What can I do to fix it? Help!
Hand wash with dawn dish soap. Then apply a good coat of wax to it.
If that dosent work, Clay bar, polish / wax.
What K3 said. If you don't have time for that right now try a spray detailer or spray wax for now.
Avoid washing your car in direct sunlight or on a hot day.Use a soap or detergent product made for washing cars, not dish soap. Dish soap can remove or cloud wax and polish coatings, detracting from the finish of the car. You have need the right materials, including car wash detergent, sponges, washing mitts and microfiber towels for drying at your local automotive retail store.
The soaps used in tunnel washes are pretty strong. Not having it rinsed right away and driving it in the sun baked the stuff on it. What you need is actual agitation to get it off. I would do a normal wash to it. A microfiber wash mitt, two buckets (one with soap, one with rinse water for your mitt) and some shade. Dry it with a waffle weave microfiber towel. If you still have streaking, then you will need to use an actual polish, paint cleaner or all on one product (aka cleaner wax). It might be a good idea anyways.
he has a obvious build up on the wax of soap deposits and wax. Using the dawn dish soap will remove these, and then as I said applying a good coat of new wax will protect the surface.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 640 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
