LED Blown Fuse/Socket
I've been replacing the lights on my Suburban with LED's, so far it's been the reverse and license plate lights as well as the DRL's which I just finished today. Last night I noticed that the taillights, license plate lights, and driver's turn signal wouldn't turn on when the headlights switched on. However, except for the license plate lights, the bulbs all still worked when I hit the brake and used a turn signal. I checked the bulbs and noticed my driver's side license plate bulb was blown, the housing all foggy and brown. I removed it and realized socket was blown and bulb destroyed and that I can't install another light on it now. I then replaced the fuse and all the lights worked again. Except the driver's side license plate light obviously.
My questions are,
What caused this? I've installed LED's before and this is the first time it's ever happened.
Should I take it to the dealer?
What part should I buy to replace the socket and how hard is it?
Where are you buying your LED bulbs? Sounds like you got a cheap defective bulb.
I ordered them from amazon but the brand was Putco. I've used these a few times because they are bright and seemed to have no issues. Until now.
Its a 194 bulb in your license plate light correct? You can just buy a new 194 pigtail and splice it back into your factory wires if the bulb socket is not salvageable anymore.
Here is an example of a 194 pigtail. http://www.amazon.com/Pigtail-Socket-Assemblies-Side-Marker/dp/B0040CZ0QI/ref=pd_sim_sbs_auto_1
Amazon has a good selection, your local auto parts store, Autozone, Advance, etc should have them as well.
Yes it is, I'll definitely take a look at Autozone and O'Reileys later today. Do you think It would be safe to use another LED for the license plate? Maybe a different brand this time around?
Alright sounds good, I'll go ahead and give those a try the second time around.
Thanks for your help Dave.
    tblt44
    tblt44
  • Who's Online   4 Members, 0 Anonymous, 608 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
