p0446 only
hmr321
I dropped the fuel tank (42 gallon) on mama's 1999 5.7 Suburban, to replace the fuel pump. Boy, are those connectors to the fuel pump a pain- even with a tool. I reinstalled the tank and now I am getting P0446 codes and ses light on. I have read several post on the vent valve and took it off to check it. Air flowed thru both directions and the filter is clean. This valve lives on the side of the canister under the hood. It is located on the side of the battery mount (second battery for towing, etc.) on the drivers side. Does not seem to be a dirt issue as the solenoid rattles and operates with a ground on the white wire. Could there be a problem that I caused when I dropped the tank? There was a soft rubber hose that connected to what appeared to be a vent of some sort on top of the fuel tank. This hose ran diagonally across the top of the tank and connected two of these vents? to a T fitting. If this hose is pinched, will that give a P0446 code? Every thing was okay until I replaced the fuel pump (not related to any code- car would not start with 18 pounds of fuel pressure).
It could. Suggest you check all lines and electrical wire and connections
No need to have multiple threads on the same subject. Pick one and stick with it next time. Topics merged
My bad. I did a copy and paste and that is what came up. Sorry bout that. I just washed my hands before I did that and I can't do anything with my fingers causing a double post.
No, you actually had two separate threads in two different forums on the same subject. No need for two. Post your problem once from now on please. Your two topics have been merged.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
