2000 Sierra Overheating
Hi everyone,
I have a 2000 GMC Sierra SLT with the 5.3 vortec engine and auto transmission with 114,000 miles. The problem began with a low coolant warning when I was on a steep incline. I added 1/2 gallon of 50/50 mixture dex-cool taking the reservoir to the max mark and everything seemed to be fine. I looked everywhere and couldn't find a leak. A couple of weeks go by and the truck starts to get slightly above 210, I checked the coolant level and it's still at the max. Now the truck climbs all the way to the 3/4 mark, it does this whether I'm driving or idling in traffic. I should point out that the truck isn't my daily driver and does a lot of sitting. It's usually only used on the weekends to work around the house or tow a small trailer. Does anyone know of common problems with this model of truck or help out in pointing me in the right direction?
Thanks!
My guess is the thermostat. Low cost easy fix, to at least aliminate that as a possible culprit. If your real frugal, take the thermostat out and boil it in water with a candy thermometer, check the temp when it opens.
Mike
If the trucks been sitting alot, I would also replace the thermostat & Dexcool/distilled water. I bet the cooling system hasn't been serviced, correct??
    Selfman
    Selfman
  • Who's Online   5 Members, 0 Anonymous, 886 Guests (See full list)
