05 silverado No audio from front left speaker (does have audio Intermi
luweee
Guys
I have no audio from my front left speaker ... Front right has audio. Then there some RARE days where I get audio back.
It is a Bose system with the amplifier..
bout 3 years ago I removed my center console and put in a JUMP seat.. so the amplifier now rests safely under the front passengers seat... (just and FYI of my current setup).
any ideas to what is going on here?
Thanks guys!
I had the same issue with my 2006. I have the BOSE setup and 100% stock. Ended up being a simple short at the speaker plug in the door. Pulled it out bent the contacts in a little bit and sprayed in some electrical contact cleaner. Haven't had any issues since. Good luck.
My whole left channel cuts out for a few minutes at a time (front and back doors on a Tahoe). Any ideas to look at for that. Figure its not the speaker connection since both speakers are effected at the same time (figuring they are wired in parallel).
  • 8 months later...
Debugged my issue. It was a loose connector to the aftermarket USA-Spec PA15-GM iPod interface.
