Adding TPMS to 3500HD
idahopool
I just picked up my new 2014 HD Denali and found out that the 3500's do not have the Tire Pressure Monitoring System (TPMS). I'm on of the group that likes to have that information. So far I have not been able to get any info from GMC that would tell me what I have to do to add this feature. It seems only logical that it could be added even if it meant changing the speedometer unit and adding the tire sensors. All it is is a sending and receiving system. Has anyone had any luck with getting this done?
If this is a single rear wheel...does it have remote start and keyless entry? If so, the correct RCDLR (Remote Control Door Lock Reciever) is already in the truck, and its the same one that is in other trucks WITH TPMS. I would like to think that...if you bought 4 sensors, and maybe a reprogram to the RCDLR and maybe the BCM and you might be able to make it work.
It's a single rear wheel truck with all the remote controls on the key fob. I agree that it should be as simple as adding the pressure sensors to the wheels and programing the RCDLR to receive the signal. So far GMC is refusing to say anything other than there is not a "kit" to accomplish this. My feeling is that there may be some legal concern on their part. I'm hoping that someone else has had this issue and found a workable solution to getting it done. Thanks for your input.
  • 2 months later...
Idahopool,
Any resolution, or news on adding OEM TPMS on the 3500s?
  • 6 years later...
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 605 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
