Not Happy
I took my 2014 Crew Cab LTZ Z71 back to the dealer last Tuesday. They were fixing a small spot between the rear bumper and the tail light, replacing a tail light bulb, tinting the windows, & Pro Pack (interior protection). Called on Thursday to check the progress since I hadn't heard anything from them. Said they were backed up but the repairs would begin Friday morning and should be finished either Saturday evening or Monday morning. At noon today, I still hadn't heard anything so I contacted them. They haven't even started working on it yet! So now my new truck has set at the dealership for almost a week with nothing being done to it.... had to vent.
I would be upset too! They could at least call if they have problems. Maybe they don't need your business!!
Sent from my Galaxy Nexus using Tapatalk
How about these solutions:
fixing a small spot between the rear bumper and the tail light - Make an appt with the body shop. No reason to let the truck set there waiting.
replacing a tail light bulb - Tell them to give you the bulb and replace it yourself.
tinting the windows - Any good trim shop can do this in 30 minutes and the finished product will look ten times better than the porter that does it at the dealer.
Pro Pack (interior protection) - Complete rip off at any price. Pass on it.
agreed
An appointment was made... For last Tuesday. They were only suppose to have the truck for a couple of days. And now after the run around it's been a week. And the pro pack has been worth it on my wife's Tahoe, 2 rips in a seat, cracked dash, and a large stain in the carpet all repaired or replaced.
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,346 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
