just trying out new sig
nonstop
:D  :(  :(  :eek:  :eek:  :D  :crazy:  :crazy: BOUNCY IS GOOD!!! I am surprised she hasn't had a concusion yet!
K1500, it wuold be cool if you could get the Cheech and Chong pic from when they get pulled over in the van :uhoh:
Tom
I wonder how it would look as a screensaver???
I wouldn't get any work done...DON'T TOUCH THE MOUSE!!!
One of the funniest cheech and chong moments is:
Cop goes up next to car, knocks on window and cheech says
"You keep on knocking but you cant come in"
:(  :(  :D  :crazy:  :crazy:  :eek:  :eek:  :lol:
Id like to have that pic!
:uhoh:  :D
