99 Silverado Front Brake Hoses
Hi I have a 99 Silverado 2500 2WD 3 door truck. I am having difficulty with front brake hoses that have rotted out. The correct Delco part numbers are 19150636 and 19150637. Unfortunately, in there infinite wisdom, GM has discontinued these and there aren't any left. Also nothing crosses to aftermarket. My truck is a early model or first design. Anyone know how to fix this problem? Can I change calipers which will make the hose now correct? Any help would be greatly appreciated.
Thanks,
Joe
Go to dormanproducts.com and check out the following part numbers and the product specifications and see if they are compatible.
H620051
H620052
You look for some steel braided lines? Should last you a lifetime and have better braking.
