Unsure of which speakers to upgrade to
2008 GMC 2500 ext cab without bose
both front speakers are out so i am looking to replace them, i am not looking for a complete set up right now. Just front speakers. Ive been looking on crutchfield and talking to a customer rep.. they suggested these
http://www.crutchfield.com/p_107DB651S/Polk-Audio-db651s.html#details-tab
But reading the reviews it doesnt seem like they are what im looking for and the rep was all about them. I also was looking at these
http://www.crutchfield.com/p_136TR650CX/JL-Audio-TR650-CXi.html?tp=94
Pretty much what i want are speakers that will put out a pretty good mix of highs/lows. But i want something that packs a bit more bass, without the need of an amp or sub (i figure this would be hard to find?). Im no audio guru, more towards mechanical side of fixing the truck, so i really am not sure of what to look for when it comes to this stuff.
What would you guys suggest for an easy replacement at a decent price?
Of the two you have listed the polk is slightly more efficient with a 92db sensitivity as compared to 91. (remember a 3db change requires about twice the power)
Also the Polk has a slightly lower frequency response starting at 50 instead of 59.
Generally I say you cannot go wrong with Polk kids/highs. If you are never going to amplify them you may be able to get just as good of sound out of some of the "cheaper" speakers.
I personally would add an amp at the same time. Or go with a cheaper speaker and use my money to add a small sub.
Just looking at the two you have posted the JL are $105 more.
That is $105 you could apply to:
http://www.crutchfield.com/p_23615XTN/MTX-ThunderForms.html
or
http://www.crutchfield.com/p_204BTA850F/Bazooka-BTA850FH.html?tp=114
Do something like these and you will be another $50 closer to a small sub.
http://www.crutchfield.com/p_109GT66/JBL-GT6-6.html?cc=07&tp=95
I am open to adding an amp i was just saying not right now just because of my budget (need speakers, tires, shocks, all that good stuff) but if i could find a good deal i could probably swing it. Is it possible to add an amp and speakers on a stock headunit? sorry im a newb.
if so is it possible for it to be under the $300 range?
thanks for the help
No experience with those but the best rule of thumb to keep in mind is the amp is more important than the speaker. Remember the speaker can only duplicate the signal that is sent to it.
If the amp is is not accurately processing the signal then.....
A speaker can handle WAY more power than it is rated for if it is a good CLEAN signal.
What you are trying to do is a tough decision.
The Alpines you have chosen have a frequency response that starts at 70. And a sensitivity of 88. That is a 3 db difference than the polks you linked earlier! That means they will be half as loud on 1 watt!
The Kickers have decent specks. I personally would go with Polk over Kicker.
I have not done car audio purchasing in several years. You may want to wait for some on some advice from somebody with current experience with what you are trying to do.
How about
http://www.crutchfield.com/p_107DB6501/Polk-Audio-db6501.html?tp=106#customer-reviews-tab
I have had good luck with the Crutchfield Open Box and Scratch and Dent
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
