06 chevy z71 possible electrical problems HELP
    • The amount of storage in the rear seat area is huge. You can keep all your cycle gear dry and clean back there
    • Truck in fluid changes and investigate subtle shudder at cruising speeds.  Told them it felt like my ‘14’s shudder when AFM kicked in.   Dealer #1 :  You need a new torque converter.   6 weeks later, after causing other damages to my truck, I get the truck back.  Same shudder exists. New, more violent shifts and vibrations at low speed.  After choice words and a few more weeks of waiting for them to replace my running boards supports, I move on to another Dealer.   Dealer #2:  The cruising speed shudder is DFM.  (I didn’t realize truck had it.) The TCM/ECM needs updates.  Updates will solve all vibration issues.   They perform updates, truck seemed ok in lot.  Not a mile down the road, SERVICE BRAKE PAD MONITOR. Dealer #1 stated brakes were at 4mm.   took truck back to Dealer #2, rear brakes at 2mm and less than 1mm.     New pads/rotors on rear, new pads up front.   truck seems good. Toggle through menus, brake monitor system is disabled.  Huh?  Why? Turn that sucker on : SERVICE BRAKE SYSTEM!     will not reset manually, automatically, or even after pulling negative bat cable for 30min.     Could the TCM/ECM updates the culprit?    A torque converter diagnosis for a “normal” shudder and now I’m thousands in the hole and the truck still isn’t right!  Beyond pissed.
    • Your right on. 👍🏻
    • Seats matter a lot.  I would start there - good advise here.  I had a 2018 LT Colorado before my 2026 LT Silverado, and the seats are so much better in the new one it's not even a contest.  That was one thing I always hated about the Colorado and I owned two of them spanning 10 years - but I did it so I could park in the garage mainly.  Now I have a much larger property and a huge barn so I have plenty of parking options and a full size is more useful for maintaining the property and current hobbies as well.  I wasn't evenb thinking about the seats as part of the reason for the move to the Silverado, but after two back to back 700mile road trips I am sold on the LT seats w/ leather 100%.  The other LT features are also nice - one thing I really like is the power rear window on the back window by the bed.  And the lighting in the bed is also very nice to have - I doubt that comes on the lower models.  Power tailgate - also quite useful - it's a heavy slug!  What else - I could take or leave the screen - but heated seats and steering wheel and cruise control on the steering wheel is very useable - I would never want to live without that.  Even the colorados had that.
    • I think the ship has sailed on the fuel injection type - everything is getting direct now.  Does it help with mpg?  Not really and nobody buying a HD truck really cares anyway.  But that is what it is at this point.  Piston rings is something they may well adjust over time to get them right.
