No pressure in Coolant hose
95z71performer
I recently lost pressure in my coolant system on my 1995 5.7 k1500 and I checked for the head gasket being bad and it's not so it there anything else that could cause there to not be any pressure
Radiator cap; they do wear out and fail. Cheap and easy, too.
already done
what about hoses getting plugged that go to the heater core that's about the only thing I haven't checked yet
That wouldn't cause a pressure loss.
FWIW, I've got a '86 Grand Marquis I've owned for what will be 11 years this coming January ... 212k miles, and that cooling system hasn't had pressure since '04. It's got a new radiator, hoses, a water pump in '06 ... still no pressure. It runs and doesn't overheat, so I'm not concerned with it. I don't have a trailer hitch on it, so it's not that big of a deal. Probably from the heater core ... but stop leak "fixed" that issue back around '03. Saved me 10 hours of labor ripping the dash out ...
Doesn't take much to bleed off pressure. A hose clamp that's a bit loose, bad gaskets, or worn out hoses will do it ... and you'll never see a puddle. They can leak so slowly that it's almost impossible to see, but when you squeeze the upper hose, it's just mush.
If it were my truck, I'd only be concerned if I lived down south, or towed alot with it. Up here it's only hot 2 months a year, so it's not a big deal.
There's also the possibility of it being a slow head gasket leak ... but lots of times the leak goes both ways, so you'd have combustion gasses in the cooling system. The other way it'll run down the block ... and those can be hard to find as well.
Interesting ....
I'm lost but a friend of mine said to try it and it worked but I'm still not getting the greatest of heat in the truck and this should've fixed it
Good time of the year to have heat! :cheers:
Was 9° here and snowing like hell yesterday. My '89 S10- Blazer with the carbed '00 4.3 was roasting me out of the cab. Heat is a good thing, at least up here .. :thumbs:
You had no heat? That's different than having no "pressure". If you had started by saying, "I have no heat coming from the heater core" then you would have had an answer quickly. That would have been to flush the system and core thoroughly and completely.
No heat and no pressure to start now just no heat
And all of this is because of a thermostat getting such and making it overheat
Yes I did twice because I got a defective one and it wasn't opening fully but we have decided to go on to other issues
Is it hard to get at the vents inside the dash
Is it hard to get at the vents inside the dash,
what does the dash vents comment mean ?,this thread is very hard to follow
are you talking air flow thru the HVAC system?
Not completely sure but its cold on one side and hot on the other and people I've talked to mentioned a flap of done kind in the dash that might not be functioning right
Are you talking about passenger side vents compared to drivers side vents?
You really need to do a better job of explaining your issues in the future. It would help us, help you better
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 529 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
