issue with heat not working
I have an issue with my heat not working once my truck gets warm...don't know why but it was working the last time I drove it but it only blows cold air..anyone know what could be wrong? Its a 02 z71
To check the heater core, you can grab both hoses as it warms up. The inlet will be warm/hot and the outlet should be the same if flow is good. You might try this:
A re-calibration may fix you up. Try disconnecting the battery for
a few minutes. Reconnect it. Or remove the HVAC/ECAS fuse for a minimum of 10 seconds.
Re-install the HVAC/ECAS fuse.
Then turn the key to the on position, but
don't start. Don't touch the HVAC controls. Let them do whatever that
want to do. Air flow may change outlet points during this time. Wait
about 1 minute. Turn key off. Sometimes opening and closing the door can
make a difference as the vehicle controls see this as "cycle"
completion. Next start the vehicle and drive it a short distance and see
how it performs..
