No Spark From Coil?!?!
I have a 97 1500 with a 5.7l and recently it started running
rough under load, but idling fine. I parked it for the night and the next
morning it then wouldn’t start. Up until that morning I hadn’t been having any
trouble with it not starting.
I hooked up my scanner and it was throwing a P0340 and P0341
codes I looked up the codes and then proceeded to head to O’Reilly and pickup a
new crankshaft sensor.
I put the new crankshaft sensor in and it still wouldn’t
start, I then proceeded to put the old one back in and it still wouldn’t start.
I then noticed that inside the crankshaft sensor box that
there was a sheet of paper that said that the new sensor would need to be “relearned”
with a scan tool. I checked my service
manual and it didn’t mention that and then called to Stealerships and both of
them said that wasn’t the case as far as they knew. I also read somewhere else as well that even if the Crankshaft sensor was bad
that the truck would still run.
I then proceeded to look into the troublecodes more and then
realized that I read the codes wrong and that the codes actually pertained to
the Camshaft sensor NOT the crankshaft sensor ;)
I then decided to replace the Camshaft sensor, distributor
cap and the rotor. Still wouldn’t start!
I also know that the crankshaft itself isn’t broken as I had
to put a wrench on it to install the sensor and the distributor shaft and rotor
were turning with the crankshaft.
I then checked the supply and ground on both the Crankshaft
and Camshaft sensor plugs and both were getting 12v.
Also there was 12v to the coil and the module that is
mounted on the side of the coil.
Then decided to try a coil from a known running truck and
still no spark.
Tested all fuses under the hood and in the cab and all
tested good.
Checked fuel pressure, that was fine.
Now after putting the new cranksensor in I’m getting a
P0339.
Wondering if maybe ECM is bad or something, like it’s not
telling the coil to engage!?!? However I would sure think that the truck would
still run but in “limp” mode or etc.
I then started to think maybe a bad ground?!? Maybe in the chassis or something?
From the battery I’m getting 12.125ish volts when turning over,
and each plug was getting 12.5v with the key on, and the headlights were strong
as well.
I even used a jumper wire on the solenoid on the starter to
rule out the ignition ON position.
I then ohm tested the coil wire from the coil to the
distributor cap and that was well within spec.
I’ve had no recent electrical problems with the truck.
Does anyone have any advice as I’m at whits end here L
  • 4 weeks later...
ive seen this before on a customers truck and it wound up being his ecm, his was due to welding on the truck without disconnecting battery cables. not saying that you have done the same but he came in talking the same way you are as far as his latest diagnostics and parts replaced. i suggested the ecm to him because i noticed a bunch of aftermarket stuff welded on and asked if he disconnected cables and he said no.Just saying
    250.3k
    RobbertClaus
    RobbertClaus
  • Who's Online   5 Members, 0 Anonymous, 508 Guests (See full list)
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
