Instant MPG screen?
I remember on the truck I test drove prior to the one I purchased (same exact truck different colors) I scrolled thru the info screen and it had a instant mpg screen and I was talking to the salesmen about it while I was driving. It's not a big deal.. But I don't seem to have the same screen in the truck I bought. Can anyone help me out?
Thanks.
The DIC lets you turn on and off info pages individually. I think you have to go to the right when looking at an info page.
There is a screen that shows instant mpg's. It also show best mpg's for your last 40, 100, & 400 miles. I believe that's the order. On mine it was disabled. You need to scroll through the settings menu with the up, down, left, right arrows on the steering wheel. I can't remember the exact location in the settings menu it was, but it is in there.
Tapatalk via Moto X
With your steering wheel control go to your options and make sure that screen is set to come on. You might have others turned off as well
I did check that and I found the average mpg wasn't on so I enabled it but there isn't a instant screen. Are there models with out it? Thank you for the responses.
Edit-- I have Speed, trip A, trip B, Fuel range, Oil life, tire pressure, fuel economy, timer, engine hours, trans temp and "blank page" in that order.
When you drive the fuel economy screen will show instantaneous mpg
Yeah its the "fuel economy" page. It shows current economy on the left, where it says 0mpg in the picture below.
Does your "fuel economy" page look different??
The fuel range page shows instantaneous MPG. The fuel economy page shows average MPG.
Edit: I guess it's different than in the Denali cluster.
On mine pretty sure that number on the left side of the bar on the Fuel Economy screen is the instant mpg, if not it sure bounces around like it is
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
