Big Block "STUD" Hoss
TxDoc
http://www.bosshosscycle.com/second.html
Big Block "STUD" Hoss Specs
Wheelbase: 82"
Height of Seat to Ground: 27"
Tank Width: Front 27" Rear 17" Front Wheel: 16"
Front Tire: Avon MT90 (130)
Rear Wheel: 7" x 15"
Rear Tire: Avon 230
Dry Weight: 1300 LBS.
Frame Width: 30"
Ground Clearance: 7"
Front Forks: Inverted
Rake: 33 degrees
Corner Lean: 25 Degrees
Frame Material: 1.5" Chrome Molly
Engine: ZZ4 502/502 CI GM Crate Motor
Horsepower: 502
Carburation 850 CFM 4-barrel
Exhaust: Ceramic Coated Headers
Mufflers: Dual
Drive Belt: Gates- Poly Chain
Drive Sprockets: 47mm with 14mm
Front: 32 Tooth
Rear: 80 Tooth
Rear Axle: Spool Type
Rear Hub: 5-6.75"
I have seen one of those beasts in person. They are 502hp of no joke. They had a special on HP TV one time and they said they go from 0 to 80 in 2 seconds, smoking the tires the whole way :crazy: The transmissions are 2 speed power glides I think, or atleast thats what I remember hearing at a bike show. Their also about 38k. Definatley one bad azz way to cruise.
 Alex
Hey Doc if you want one a friend of mine sells them he has some bikes and the latest thing is trikes that from the back look like 57 Chevs.  You can get the BBC or they do come in a milder SBC if you choose but the price is close to the same.
    Kirk Belch
    Kirk Belch
  • Who's Online   5 Members, 0 Anonymous, 1,328 Guests (See full list)
