Power Mirror Glass Removal
Well here goes,
I have a 2008 GMT900 Sierra 2500HD with DPN vertical camper mirrors.
I'm having issues with the mirror motor and want to take the glass off to take a look. I have driven myself crazy trying to find out how to do this. All I can find is how to take the GMT800 mirror glass off.
Any help would be great.
ttyl,Dave
push the glass at the top and look in with a flashlight through bottom, there should he a little slot put a flat head screwdriver in and pop out te glass carefully from the actuator, your actuator is what would be giving you problems, there really isnt much to see though its just a little motor encased in plastic and the wire harness runs into the truck pillar.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
