Ecoboost 2.7 Article....
I don't know.
Maybe I'm to stubborn for this.
2.7L in a full size truck.
It's like a Harley with a Vespa engine...
I can hear the engine screaming already just to get up the hill. But maybe that's what the 10 speed trans is for.
I still can't believe that a turbo charged 2.7L will get better mpg's than a 5.0-ishL V8, both with a 10 speed trans.
so long
j-ten-ner
I know... I'm sure it will push it but I just can't wait to hear the first guy to hack off the muffler and put a video on YouTube lol
This engine is targeted towards people who will use it as a car. They just want a truck but really need a car and with this they get both attributes, even if its in a highly compromised package.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
