my link apps
  • 5 years later...
On 1/20/2014 at 11:04 PM, 8KCAB said:
So what happens to the OnStar Nav when your subscription expires? Do you lose nav altogether? From what I have been reading, the factory nav seems to be better in terms of user interface and apps...
When OnStar is not activated you get nothing, no navigation just to be directed to OnStar if the icon is pressed. Really dislike the OnStar setup. Don’t buy a truck with the OnStar you will be highly disappointed.
Onstar nav is turn by turn. No physical map onscreen. So if you only have onstar nav, when your subscription ends, so does your turn by turn nav. There is no fee for the factory nav. But if you have Android Auto, you can use Waze or Google Maps for free. I use Waze before my factory nav anymore.
I wouldnt necessarily say that. I always have it for an emergency or stolen vehicle, and some phone minutes. Some hate it and would never pay for it, and some love it. Yes, its expensive. And I dont think you have the choice to buy a truck without it. Unless its a base model I think. Even then, it might be standard. But again, its subscription based.
Maybe it should be, dont buy FOR the Onstar....
You need an antenna, usb hub, hmi, and programming for the hmi. Check out the 2.0 to 2.5 module upgrade thread.   WAMS or Mag can help you out.
10 minutes ago, Brent111 said:
How do i get nav on my 2016? do i need to take it to the dealer?
Do you have android auto or car play already? Just use google maps or waze. Its free and work better. Most of us dont even use factory nav anymore.
I’ll sell u a 2.5 hmi with navigation “200$”, I actually like the way the factory 2019 maps looks on the screen then the google maps
Now thats a smoking deal. Still need an antenna. But thats cheap too.
I think the antenna cheap af on eBay but I’m selling these things
hmi2.5 with navigation 200$
8in screen with digital AC buttons 100$
radio module “Bose equipped” 100$
denail cluster 300$
Black Leather stitched dash 200$
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
