6.2l L9H Rev limiter?
Looking to see what all you guys are running for rev limiters on the 6.2's! I was suprised to see that stock was right at 6k or so. Recently bumped my shift points to 5950 but wondering if i can bump that limiter up and rev it out some more in each gear!
All stock motor and no problems? I figured it would be up near 6500 or 6700 since thats what the ls3's and l92's are running. Just figured i would ask before tuning blind.
I don't see much issue with it, other than that our intake valves aren't hollow stems like the LS3s, so I wouldn't push it past 6500. Also, with the stock cam, this motor is out of breath by 6k RPM so you won't see any benefit in doing so.
My 2013 6.2 has a 6100 rpm limiter. I wouldn't go much past that unless these engines have the same springs as the LS3. Which I doubt. And like Jonathan says, this cam runs out of breath by 6K.
