project cars/trucks
95z71performer
20140127_220343_zpsc7257260.jpgput the cab on this truck today. I will be painting it hugger orange soon after hanging the doors. The frame was powder coated silvervane and came out real nice. It is fare from being buwt i am only responsible for the paint and body work. I am bringing home a 65 mustang that needs a new roof skin this week.
  • 1 month later...
No room for one would love a 68-70 chevelle.
Just mod my camaro. Not much more to really do as I just added new rims this December. Going to hydro dip a few interior pieces when it warms up a bit
Ryan
Great looking camaro. Looking at getting a blacked out SS here pretty soon.
Ryan
I love your camaro. Im picking up a 2014 2SS 1LE here in the next couple weeks. I'll post some pics on the camro5 forum :)
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
