Yeah I've seen them. They're made a few hours from my home. Still like a 3-4 week wait because they're made to order. I almost ordered the Iron Cross low profile the other day. Who makes your grille?
I like it man! It's super clean! And almost anything is light compared to OEM stuff. It's crazy how it's mainly the cheaper item they use vs what you and I would use is a world of difference.
My "Retirement Tan" 2015 with 2" leveling kit and camo bed decals (which is a nice subtle touch on this color).
Leveling kit with AT tires
Not done yet but here's mine with the bumpers and grill surround painted body color, T-Rex grill insert with blacked out grill center, Bushwacker Pocket flares, Ridgid D2 lights, front valance removed and Grid off-road GD5 with General Grabber 305-50/20.
Trying to decide if I should get BORA wheel spacers to make the tire stick out more or not! Let's hear you guys consensus on it!
:thumbs:
Edited by Rob21sf
Picked up my 2015 double cab about a month and a half ago, definitely my favorite color on these trucks. I live down a dirt road and I've never seen a color hide dirt this well, the back of the truck can be completely covered with dust but there's no way of knowing until you are standing a foot away and really looking for it. The iridium metallic truck we have turns two-tone in the same conditions, dusty on bottom and iridium on top.
Unfortunate that they don't offer this color anymore but I'm sure glad I snagged one.
Edited by ValidUsername
:thumbs:
Very nice looking truck! I vote no on the spacers unless you have issues with rubbing.
:thumbs:
Looks great!
Looks good.
Looks great!
Thanks guys! Almost done, I did end up adding a BORA 1.75" spacer and looks much better IMO. Before I had slight rubbing when backing up with the wheels turned and unfortunately it's still there even after adding the spacer kit but, only when backing up though!
Latest addition: Spyder headlights (Vipmotoz) with Morimoto HID (TRS) and Diode Dynamics switchbacks, Ready-lift SST 4" kit and Smittybilt Defender rack.
Still to come: Go-Rhino 40" wind deflector, Morimoto X-Torch 20" & 50" light bar, Doug Thorley Longtube headers, Blackbear Performance tune.
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 2,406 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
