G80 replacement options?
So my G80 diff decided one day at about 50mph the try to engage both axles (Black ice on the interstate). That didn't go too well... Luckily this was all that happened, but now my truck is an open diff. I've done some research, but not a whole lot was found on replacement parts for these differentials. My question is, what is the best replacement/upgrade? I prefer not to use another g80 simply because it's a low speed locking gov. Not a fan of this.
I'm planning on going with a Detroit TruTrac eventually. I've done a lot of research on it and that seems to be the best option for me.
Yukon Grizzly locker
Modelled just like the truetrac but has better warranty and read a review somewhere where a guy broke both of them down and the only difference is that the grizzly had two large washers on the ends of each spring which he said helped distribute the load more evenly when it engages, idk much about the internals of a locker I'm just trying to remember what he said.
My grizzly locker always tries to engage while turning which sucks because you get the bounce up through the cab and such. Gets better with age, but Detroit truetrac is proven
Sent while drinkin' a cold one...
Back when I swapped gears in my 2003 truck I went with a Eaton Limited Slip Differential (a true LSD), I was very satisfied with it, super smooth. My roommate had a Detroit tru-trac that was beaten pretty hard (6.0L swap, cam, stall, +all the other goodies), it never had an issue and was smooth as glass.
