Twin 125s
General Lee 01
The Twin 125s happened today, nothing really spectacular happened execpt foraclosecall for Steve Park ina race #1 & and collision in the pits between Kurt Busch & Kevin Harvick.
Race 1: Robby Gordon won with a pass in the pits due to Jeff Green being blocked byJeff Burton in the pits.
Race 2: The big  accident in the pits happened when The leader (Jr. ) made aquick entry onto pitroad which threw everybody off, sorta like what happened in the Bud shootout when they made that last pit-stop. Kurt  Busch was in one of the outer lanes on the  track going full speed. When he saw everybody else dive on to pit-lane, he slammed on the brakes and jumped down to pit-road, cutting everybody off.
He was all the way over on the outside of pit road when he came up to his stall, so he slammed onhisbrakes again,and d made a 45 degree turn infront of Kevin Harvick. Harvick had no time to stop and react, so he hit Busch,spinning him out into his pit-stall where the car tapped his jackman (luckily, no-one was injured ).
Harvicks Right front corner was caved in a good bit, Nascar officialsmadein  come back in to repair it, which he just decided to bring it behind the wall and call it quits.
Dale Jr. won Race 2
After it was all said and done, the only regular (who intended to run the full schedule) who ended up "Going home" was Larry Foyt in the #14 car.
The best part was the interview with Dale Jr. I just saw on Sportscenter.   :smash:    They asked him about how strong RCR is vs DEI.  He talked about how RCR has always been strong at Daytona, and they learned alot over this past offseason, but if you put him and Michael up against any two fo the RCR drivers they'll whip'em everytime.   :smash:    I loved it!!!   The only RCR driver I like is Harvick, I can't stand the other two.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
