Beware factory mud flap installation instructions incorrect
GMCBUD
I just purchased a 2014 GMC SLT and it didn't come with factory mud flaps. so I purchased a set from my local GMC dealer. following the instructions I drilled two 9mm holes for the knurled nutserts only to find out that 9mm is about .8mm too large so now I have 2 9mm holes in my fender that don't retain the top two mounting points (nutserts) for my front mud flaps. I tried contacting GMC using their customer service website, only to be told that I must have done something wrong and they recommend that only qualified service techs install mud flaps. I'm posting here to let some other unsuspecting new owner know about this problem to save them the same aggravation! It seems like some customer service people from GM are following this site so maybe GM will actually look at the instructions and correct them. Needless to say I'm upset that I have 2 oversized holes in my new truck that are not holding my mud flaps on.!
I have installed the exact same mudflaps on my truck.
The NUTSERT holes are slightly bigger on purpose.
Nutsert are inserted in the hole, and them crimped to a tight fit. similar to a rivet.
You need a special tool to crimp the nutserts, although if you research online you can make an
intallation tool from a bolt and 2 nuts and maybe a washer.
good luck!
I just installed the Chevy version and yes, it looks like the holes are a bit oversized but when you crimp the rivnut it captures it just fine.
Be forewarned, the bolt, nut and washer home made tools posted all over the Internet DO NOT WORK. The supplied rivnut's are steel and the home made tools only work correctly with aluminum rivnut's.
Either purchase or rent the proper tool or see if your dealer can install the rivnut's for you. Or, simply bag the rivnut's and use a sheet metal screw, it will hold just fine.
This tool works well for the price. http://www.amazon.com/gp/product/B004KLVJAA/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
yes the steel nutserts are difficult to crimp.
I used the cheap style nutsert installer that looks like a rivet gun and also a C-clamp to help crimp them tight
    Bulldogger
    Bulldogger
  • Who's Online   4 Members, 2 Anonymous, 847 Guests (See full list)
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way to big should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crosing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
