Issues with 2008 silverado 4.8l o2 sensors P1133 warranty almost up&#
Hi All! I'm wondering if anybody has experienced something similar. My truck is a 2008 Silverado with a 4.8l with 44,000 miles on it. I just bought it and CEL came on throwing a P1133 Insufficient switching code Bank 1 sensor 1. I have a 30 day warranty from the lot I bought it from, so I took it back and they said the O2 was lazy and they changed it. less then 100 miles and CEL comes back on. I plugged in my OBD2 reader and got the same code P1133 Insufficient switching... I only have two weeks left on my warranty. What should I be looking for? Does this sound like symptoms of a cracked manifold or head gasket leak?
Here is the freeze frame data if that helps get this narrowed down.
Fuel sys 1 CL
Fuel sys 2 CL
Calc load(%) 46.7
ECT(F) 176.0
STFT B1(%) 2.3
LTFT B1(%) 4.7
STFT B2(%) 3.1
LTFT B2(%) 3.1
Fuel Pres PSI 42.6
MAP(in Hg) 16.5
engine rpm 1268
veh speed mph 48
spark adv. 31.5
IAT(F) 8.6
MAF(lb/min) 3.2
TPS%
Run time(sec) 655
Command Evap(%) 39.2
Fuel Level(%) 39.6
Warm up DTC- Clr 2
Clt dist(miles) 77
EVAP VP(in H2O) -1.610
BARO(in Hg) 28.6
Cat te 11(F) 1315.4
Cat te 21(F) 1299.2
ECU volts 13.720
Load value (%) 39.6
EQ ratio 0.999
re T|PS(%) 16.9
Ambient (F) 6.8
TPS B(%) 31.0
ACC pedal D (%) 26.3
ACC pedal E (%) 12.9
Command TAC(%) 24.7
take it back now !! ,,,,dont help them at all,,,,,,could be alot of things and you're out of time
let us know what they do
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
